adam6604 Posted August 13, 2011 Report Posted August 13, 2011 dont think you need the H/O alt or anything, im running stock everything with all 1/0awg wire and a extra Kinetik HC1400 with the same sub amp as you and i have very little voltage drop if any Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi. Audio: Two 10" Alpine Type R's ( 1000rms models ) Hifonics BRZ 2400.1D @ .5 ohm Two Kinetic 1400 batteries ( soon to have XS power under hood ) Tsunami 1/0 Awg wire throughout truck. Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine. Exterior: 17"Dick cepek rims with 33" Toyo MT tires Bushwacker fender flares Magnaflow true duel exhaust LED tail lights with Projector headlights Plasti-dip fun coming soon!
MatthewBigBossWilliams Posted August 13, 2011 Author Report Posted August 13, 2011 I'd suggest a small 4 channel that maybe matches brand on whatever sub/mono amp you choose. *Edit- Your shopping list has changed so much, I'm not sure if you know what you're wanting, or why you're wanting it. yea it has. heres the new list and pricing Dynamat Xtreme 20' Trunk Kit 19405 = $105.00 Protection plan Rockford Fosgate PRIME R300-4 = $146.98 - door speakers amp Protection Plan Hifonics Brutus BRZ2400.1D = $368.98 - Sub amp Protection Plan The Install Bay IB500 = $54.99 - Battery Isolator Kinetik HC 2000 = $533.96 - Batteries Protection plan Rockford Fosgate R1682 = $89.98 - Door Speakers JVC KD-R900 = $222.98 - Head Unit Get wiring Harness, Dash Kit, Antenna Adapter Protection plan Vibe Audio Black Box Stereo(BlackBS2-V1) - $166.98 - Loud Horns amp Protection plan Selenium D250-X 1" Phenolic Horn Driver 1-3/8"-18 TPI = $$73.98 - Lour Horns Drivers Selenium HL14-25 1" Exponential Horn 45x45 1-3/8"-18 TPI = $9.98 - Loud horns Cones Products KFX8BK - 15qty - $10.35 - gauge wiring KFX0BK - 40qty - $158.00 - 0gauge wiring RT1/0516BK - 10qty - $17.50 - Black terminals RT1/0516R -10qty - $17.50 - Red Terminals Quanty is done by foot so 1qty = 1ft FI BL 12 = 836.80 - Subwoofers Configure Speaker Ohm: dual 1 Hyper Pole: no Cooling: yes Flatwind: no Daily or SPL: daily Universal: no Dustcap: Chrome Coil Size: 4in Quantity: 2 Larrys Extreme audio - $375.00 - box build (this is still up in the air) Mark alternator install - $75.00 alternator order - $400.00
MatthewBigBossWilliams Posted August 13, 2011 Author Report Posted August 13, 2011 dont think you need the H/O alt or anything, im running stock everything with all 1/0awg wire and a extra Kinetik HC1400 with the same sub amp as you and i have very little voltage drop if any Your the 2nd guy that said something about that H/O alt. I think i posted that my stock alt is shit and I want that H/O for later use so imma gettin it
CleanSierra Posted August 13, 2011 Report Posted August 13, 2011 That four channel Is reasonsbly priced, and was what I thought of suggesting. It should be fine for 4 door speakers. They aren't terribly efficient, but it'll get the job done. You might consider a component set for the front though. Aren't you thinking about 6X8s? Im not the one you want to try to troll. Just a fyi for you.
MatthewBigBossWilliams Posted August 13, 2011 Author Report Posted August 13, 2011 That four channel Is reasonsbly priced, and was what I thought of suggesting. It should be fine for 4 door speakers. They aren't terribly efficient, but it'll get the job done. You might consider a component set for the front though. Aren't you thinking about 6X8s? yea i am. what kind of set?
