whinning and turn off thump noise w my system
Ok i have a pioneer avic n3 headunit and the clarion eq.. i have the big 3 done in 0gauge my amp is grounded w 4 gauge through a distrib block w 0 gauge to the frame of my escalade.. when i turn off the key and open the door(gm keeps the radio playing until you open the door)i get a loud thump from shuting down the system and i have really bad engine whine.. i havent grounded the headunit like ive heard about the pioneer units needing.. thats becuz how do you ground the rcas outputs when they are the plug in(pig tail) wiring harness style instead of pluggin the rcas directly into the deck... also when i use my phone off the aux output of the clarion eq then there is no engine whine and i used to have the eq grounded thru the head unit and stock wiring harness ground and the other day when i changed the eq ground straight to the frame then my engine whine got even louder.. can someone help me out w grounding my pioneer and what can i do to get rid of the thump when i turn it off.. ps i have searched plenty on the site for this and nothing says about grounding this style of rca outputs.. thanks
pioneer avic-n3 w ipod adapter
clarion eq
infinity kappa perfect 6.1
infinity kappa perfect 5.25
infinity kappa 6x9's
2 boston spg555's
Boston acoustics gt-42
Boston acoustics gt-28
Big 3
Knu 0 gauge
Optima battery
Take a length of wire....take one end of wire strip it back enough to wrap around rca.take other end and touch chassis of deck if engine nosie goes away.afix end with ring terminaland find screw hole to mount that and maybe sap bit of solder
Anyone here familiar with this pioneer wiring harness.. it has a black wire and a yellow wire w black tracer and they both go into a lil black box and come out the other side.. well i bought the deck used and the person cut the black box off the wiring harness.. so i can still access the 2 wires but its missing what i guess is the noise filter.. do i need a new pioneer harness w this on it or i can still use this one and also still be able to fix my issue.. thanks
clarion eq
2 boston spg555's
Big 3
Knu 0 gauge
Optima battery
Sorry.and dab of solder on rca end n wire to hold in place.
Thanks!!
clarion eq
2 boston spg555's
Big 3
Knu 0 gauge
Optima battery
Can someone PLEASEEEEE!!!!!! help me
clarion eq
2 boston spg555's
Big 3
Knu 0 gauge
Optima battery
I had the same thump, it was only untill i redid my remote wire that it went away.. also that was after i blew my amp up... so it could of possibly been the amp. But I am more sure that it was the remote wire that was causing the amplifier/subs to turn off after the head unit which creates the thump.
Sounds like a bad ground to me
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
  • Who's Online   0 Members, 0 Anonymous, 1351 Guests (See full list)
