under hood battery wiring
just tryin to keep my voltage up. so im guessing more current.
If you want more voltage, wire it in series, from one battery to the other, + to -, the remaining - just ground it to wherever it needs to go, and the other + just go where you need it to go.
Correct me if I'm mistaken at some point.
wire it in series then, if you wire it in paralel you will get a different voltage i believe.
i remeber wiring 4 kinetiks into 16v it was wired series and parlele because 2 of the batts were modded
Series wiring = more voltage
Parallel wiring = more current
well i got a chevy truck and removed the storage compartment under the hood. so my main battery is on the pass side and thats where my alt is hooked up to and my power wire it ran from. the other battery is on the drivers side. i have both positives connected and the second battery is grounded to the chassis. soo idk how its set up really. for it to be parallel wouldnt it be + to + and - to -?
  • Who's Online   1 Member, 0 Anonymous, 1142 Guests (See full list)
