Top screwed. I did not glue it to allow me to remove it if any adjustments need to be made. Joints were all sealed with caulk.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
All edges were routered....well rounded with a router bit in an all-in-one cutting tool. Sub holes were rounded top and bottom as well.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Looking in port with top on. The divider gets primer later so no black showing.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
MTX TR7512-22 to be mounted.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Subs mounted.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Close-up with screw detail.
I will say one miscalculation I did is I wanted to mount the subs centered between the front panel and the back port wall but mounted it centered between the front and back wall. Don't think it makes a difference though with the back port leg being so short 3 1/2".
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Amp and cap mounted in storage compartment.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Close-up with blue LED lights mounted on both sides wired to lighted toggle switch that is mounted in space under the head unit so I can turn it off/on at will. Have to get a pic of head unit and switch later.
No fuse between cap and amp which I may should have.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Box done outside of vehicle.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Locked and loaded.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
