LoudBurp Posted August 24, 2011 Report Posted August 24, 2011 So I just got my voltmeter today and was wondering where I should put it. I have 2 ideas in mind if you guys could let me know what you think it would be greatly appreciated So one spot is in the ash tray, so that it can be hidden away discretely.... or should I replace the factory cigarette lighter with it and be able to use those wires to power it? Best of Luck and Cheers! There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
tonedeaf Posted August 24, 2011 Report Posted August 24, 2011 For the best results, you want to run the power wire to your sub amp. Your battery at your bank and at the amp are normally different, therfore I think that one that matters is what you're seeing at the amp. As for the ash tray, why would you want to ever 'hide it away' discreetly. Id rather always be able to see my voltage without having a tray open. Just my 2 cents. Be creative and you can find 20 more places to put it that would work fine.
LoudBurp Posted August 24, 2011 Author Report Posted August 24, 2011 For the best results, you want to run the power wire to your sub amp. Your battery at your bank and at the amp are normally different, therfore I think that one that matters is what you're seeing at the amp. As for the ash tray, why would you want to ever 'hide it away' discreetly. Id rather always be able to see my voltage without having a tray open. Just my 2 cents. Be creative and you can find 20 more places to put it that would work fine. This meter has 4 wires, 2 for supply and 2 for the measurement. The supply is what I am talking about when splicing the lighter out of it and the measurement wires are going to go right to the amp Best of Luck and Cheers! There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
