cavi52 Posted September 2, 2011 Report Share Posted September 2, 2011 im trying to build a box for my 10in l5... can someone give me any help its for a cavalier. i dont no how to post the box calculator so here are my specs. height=13 width=49 depth=13 port dimensions height=11.5 width=1.25 legth=7 miscellaneous woofer displacment .02? idk what to put there baffles=1 baffle thickness=.75 common port walls=3 thanks for your help i want it tunes around 34 Quote Link to comment Share on other sites More sharing options...
CleanSierra Posted September 2, 2011 Report Share Posted September 2, 2011 I'd go longer with that port, like 28 inches. I plugged it into Torres with your other dimensions and get mid 34's and 1.01 cubes after displacement. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
cavi52 Posted September 2, 2011 Author Report Share Posted September 2, 2011 I'd go longer with that port, like 28 inches. I plugged it into Torres with your other dimensions and get mid 34's and 1.01 cubes after displacement. Quote Link to comment Share on other sites More sharing options...
cavi52 Posted September 2, 2011 Author Report Share Posted September 2, 2011 my depth is only 13 Quote Link to comment Share on other sites More sharing options...
CleanSierra Posted September 2, 2011 Report Share Posted September 2, 2011 I'd go longer with that port, like 28 inches. I plugged it into Torres with your other dimensions and get mid 34's and 1.01 cubes after displacement. Ooops sorry, I didn't get one of the dimensions in correctly. I will go back and fix. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CleanSierra Posted September 2, 2011 Report Share Posted September 2, 2011 my depth is only 13 Correct, but the port can take a 90 degree turn and head parallel with the width on the box Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
cavi52 Posted September 2, 2011 Author Report Share Posted September 2, 2011 I'd go longer with that port, like 28 inches. I plugged it into Torres with your other dimensions and get mid 34's and 1.01 cubes after displacement. Ooops sorry, I didn't get one of the dimensions in correctly. I will go back and fix. Quote Link to comment Share on other sites More sharing options...
cavi52 Posted September 2, 2011 Author Report Share Posted September 2, 2011 k Quote Link to comment Share on other sites More sharing options...
CleanSierra Posted September 2, 2011 Report Share Posted September 2, 2011 k Ok I got it, but it's tuned about mid 35's which should sound badass. H13" W26" D13'. Your port will be H11.5" W1.5" and D30". It can be 30 because it heads toward the back of the box until it's 1.5 inches off of the back wall, then it turns 90 degrees and heads another 15.5 inches. It would have 15.68 inches of port per foot and should be plenty. I guessed the sub displacement at .12 Cubes. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
cavi52 Posted September 2, 2011 Author Report Share Posted September 2, 2011 k Ok I got it, but it's tuned about mid 35's which should sound badass. H13" W26" D13'. Your port will be H11.5" W1.5" and D30". It can be 30 because it heads toward the back of the box until it's 1.5 inches off of the back wall, then it turns 90 degrees and heads another 15.5 inches. It would have 15.68 inches of port per foot and should be plenty. I guessed the sub displacement at .12 Cubes. can you make a digram of it by any chance i dont get the off the back wall Quote Link to comment Share on other sites More sharing options...
