I'm sure of us has had the problem with the cluster in your truck. The gauges stick from time to time or making a clicking noise. Here are some steps to fix it if you want to DIY.
Edited by Bigballa39213
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
First you take off the front plastic clear cover.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Then you turn all of the needles clockwise till they stop. Then you place a strip of tape alone where the each needle rest so you can make its resting point.
Then you turn each needle counter clockwise to its resting point then mark it.
Stock Everything
The New Setup
4 - RE Audio SX12D4
After you mark the resting points next you turn each past that point till you feel the seal loosen. Turn and slightly pull at the same time to remove each needle.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Now you remove the back cover.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Where were you when I needed you 5 years ago? I have replaced my entire cluster 3 times. That's a total of 4 different clusters I've had in my 03 Sierra.
Now you should be able to remove the board from the front trim. Be careful some of these have a wire harness connected to them for the message center.
Stock Everything
The New Setup
4 - RE Audio SX12D4
I know. I do this almost everyday. It's really easy.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Each stepper motor has 4 legs on it that are soldered to the board.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Now the best thing to use is a desoldering braid and a good not cheap soldering iron to remove the solder from the stepper motor legs.
Stock Everything
The New Setup
4 - RE Audio SX12D4
