98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
The X C5 168 stepper motor is has been declared defective by GM and we are replacing it with the X25 168
Stock Everything
The New Setup
4 - RE Audio SX12D4
Now install your new stepper motor and solder onto place.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Now you can place the board back into the front trim. Don't forget to plug your message center harness back up if you have one.
Edited by Bigballa39213
Stock Everything
The New Setup
4 - RE Audio SX12D4
good write up, seems simple.
how much do you charge to do this and what does the new stepper motor cost?
might have to try it out :peepwall: and charge some people on craigslist for repairs
you can cook bacon shirtless if you're not a pussy...lol
not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be.
DC.jpgDC POWER
I charge $100 to fix the problem gauge and $150 for a total rebuild.
Stepper motors are usually around $5 each unless you buy in bulk.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Now snap your back cover back on.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Now place your needle at the 12 o'clock position and press into place. Then turn them to the marks you made earlier. Make sure its not real easy to turn because you want the stepper motor at its stopping point as you move it into place.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Now remove the tape snap the front cover on and you're done.
Stock Everything
The New Setup
4 - RE Audio SX12D4
  • 2 months later...
Back at it again.
Stock Everything
The New Setup
4 - RE Audio SX12D4
  • Who's Online   0 Members, 0 Anonymous, 1623 Guests (See full list)
