HotRodHam Posted September 5, 2011 Report Posted September 5, 2011 ok so im making a fiberglass box for 4 12" audioque sdc2.0s and i wanted to know if someone could tell me how big of an aero port i would need. this is the design im going for. the box will be 8cuft after port and disp. so i need to know the displacement of the port. this is how i want the subs and port set up in my box EDIT: i want it tuned to 34 hz 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
bkolfo4 Posted September 5, 2011 Report Posted September 5, 2011 At least 10" diameter with flares at both ends. Using 32 Hz and guessing the end correction, it will need to be ~20" long. That will displace somewhere around 1 cuft, once again the exact displacement would depend on the flares. You could always do more port area, but with flares, a 10" port will already be as big as one of the 12" subs on the baffle. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
bkolfo4 Posted September 5, 2011 Report Posted September 5, 2011 After your edit - the 10" port would drop to 17" long for 34 Hz and only displace .8 cuft. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
HotRodHam Posted September 5, 2011 Author Report Posted September 5, 2011 After your edit - the 10" port would drop to 17" long for 34 Hz and only displace .8 cuft. so 1 10" port 17" long with flares on each end will be good enough for all 4 12s? 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
bkolfo4 Posted September 5, 2011 Report Posted September 5, 2011 You can definitely go larger, but the port will become larger than the subs. How much depth do you have to work with? Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
HotRodHam Posted September 5, 2011 Author Report Posted September 5, 2011 You can definitely go larger, but the port will become larger than the subs. How much depth do you have to work with? i tubbed out my spare tire well so around 30" from top to bottom. probably more though. ide say 25" to be saf idk how tall my box is going to be yet. and is that 17" with the flares? or 17" long tube and like 1" flares EDIT: i wanna keep my port smaller then my subs 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
HotRodHam Posted September 5, 2011 Author Report Posted September 5, 2011 but i gotta go to work now so ill be back on later to discuss this 18" Sundown Zv4 D2JL 1000/1 V1XS Power D3200
bkolfo4 Posted September 6, 2011 Report Posted September 6, 2011 Well a 10" port with 1" flares would be 12". . . 17" total length. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
DeepBassAddiction Posted September 6, 2011 Report Posted September 6, 2011 if you could give me your dimensions that your working with or at least the area you can work with i could throw you something together quite fast with a video and cut sheets -My Box BuildLog- -FREE DDZ's-
