Soldering the wire on the inputs of amps are a big no no. Reason being, the wire can't conform to the terminal as well as bare wire. Therefore, you get less contact (more resistance) and you'll start having problems. Call Rockford, they will tell you soldering the inputs are a bad idea as well.
solder the ends of the cable then it cant squish that's what i do to insure a solid connection. and its still a clean look
THAT, sir, is a great idea! :clapping:
Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R
DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz
Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage
Silver Flute 8" midbass in doors powered by Alpine 3539
Alpine CDA-117 HU
I've put 4 gauge in an amp meant to take 1/0 (don't ask) but that bitch didn't go anywhere. Just make it tight tight.
formerly known as Jaylor Swift
