Pittcrew Posted September 7, 2011 Report Posted September 7, 2011 Hey guys, I'm still a beginner when it comes car audio and was thinking about getting a couple Fi BTL's. Now I notice they have several customization options, so I'm just trying to figure out what they mean exactly so I know I'm getting exactly what I want. I'm looking to get two, Fi N2 BTL, 18" subs So here are the options that I'm confused about: Ohm: Dual 1 and Dual 2? I'm assuming that means that each sub is dual voice coil so you have a 1 or 2 ohm option? I'm planning on running each of these on an AQ2200d (assuming that is a good amp to run it on, if you have any better suggestions please let me know) so would I want 1 or 2 ohm? P Champfer: I have no idea what this is Cooling: Not sure exactly what this is either HiXM Coil: No idea Daily or SPL: this will be a daily system but I'm still looking for max SPL so what is the best option? what does this option actually change on the subwoofer? Universal: No idea what this is either I was thinking about maybe an AQ3500D being better for a BTL rather than a AQ2200D or is that too much? I'm really not sure. Thanks for help in advance My build: 2001 Toyota Camry two 12" Kicker l7 Solo-Barics Kicker 1500ZX Amp 0-AG Wiring Pioneer DEH-3300UB Head-Unit
DylanH Posted September 7, 2011 Report Posted September 7, 2011 Got this from the Fi website. Also are you thinking about running a 2200 for the pair or each? What does your electrical consist of? Just some questions most people will ask. Hope I helped in at least some way. P Chamfer: This is a chamfer on the end of the pole, it helps to bring the air down around inside of the motor and helps cool the coil better. It also helps relieve the pressure underneath the dustcap. We recommend at the bare minimum to get this option if you choose this series of woofers. Cooling: Self explanatory, the cooling channels are machined into the inside of the sub to help cool the coil FAR better. But there are some things that you sacrifice. There is less metal inside of the motor so it is a little weaker. If you are looking for a tone/burp only scenario for SPL we suggest that you do NOT get this option. Stick with only the P chamfer. Now if you are looking for a daily sub to beat on and you have 2000+ watts the BTL series is for you. Flatwind: The flatwire coil option is standard in the BTL. HiXmCoil: This coil is simply much longer than the normal dual 1ohm or dual 2ohm flatwire coils and allows for more xmax. If you are using this in a daily scenario we suggest that you choose this option, especially in the 15 and 18 inch models. Inner Heat Sink: Its a machined aluminum ring in the gap that lowers the voicecoils inductance (allowing it to play up higher and have a little better overall transient response). It also reduces the volume inside the magnet gap of the motor increasing air speed with the cooling as well as allowing the coil to kick off heat to a more receptive thermal mass rather than magnets. Daily or SPL: Simply put, if you plan on listening to any type of music you MUST choose the daily option. If it is strictly for a competion/tone only scenario then choose the SPL option. The reason we have these options is the gap tolerances between the two are different. The gap in the SPL woofer is much tighter and FAR less forgiving in comparison to the Daily option. The Daily option simply gives the coil more wiggle room inside of the gap to deal with the non-linearity tendencies that you can get into when you are using a sub in a daily driving scenario. Typically SPL applications deal with 1 note and it does not change, therefore we can make the gap much tighter and get all of the motor strength that we can out of it. Universal: This option gives you the choice to later chance the impedence of your voice coils. You can change from dual 2’s to dual 1’s and vice versa by reconing them. If you do not choose this option your motor(s) will be optimized per the coil resistance that you have chosen. (Dual 2’s will forever be a dual 2 motor, Dual 1 will forever be a Dual 1 motor). Enclosures: BTL 12 – Ported box we recommend using 1.75-2.5 cubic feet @ 30-35Hz (I personally think that a 32hz tuning is optimal, and has the most output and is still the most musical daily driving). Use 12-16 square inches of vent area per cubic foot of volume. BTL 15 – Ported box we recommend using 3-5 cubic feet @ 30-35Hz. Again use 12-16 square inches of vent area per cubic foot of volume. BTL 18 – Ported box we recommend using 5-8 cubic feet @ 30-35Hz tuning, you can tune a little higher if you wish but we recommend keeping it close to 32hz for a daily driver. Again the same 12-16 square inches of area applies per cubic foot of volume. http://www.youtube.c...er/SmallTownSPL 2002 Chevy Blazer Substage: Shhh, its a secret Mids and Highs: Stock-Going to change soon Amp:MTX 92001 Wire:1/0 Welding cable Electrical:Stock http://www.stevemead...__fromsearch__1 I hope she was meaning that to you. Any who.... You dont say you wanna have dinner in the first damn post. talk to her first. I say find out if the status was torwards you.. Here try this... "Hey hows it going ( notice smiley face makes everything better ) I saw your status. "You are far from usual".... So is my dick... Wanna Fuck tommorow???" Or send her message saying "hey" she replies back "hey" when this happens reply Wanna fuck (INSERT ADDRESS HERE) Quote of the SPL Creed ; back in the day my girlfriend gave me a choice between her and my love for car audio, I told that bitch I've made harder decisions at the Coke machine.
Azagtoth502 Posted September 7, 2011 Report Posted September 7, 2011 https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154e66f6e206e63/shopdata/0070_Tech/0070_Speakers/0010_Tech.BTL/product_overview.shopscript Slow on the draw I was. pa-pa-platypus sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
Pittcrew Posted September 7, 2011 Author Report Posted September 7, 2011 Got this from the Fi website. Also are you thinking about running a 2200 for the pair or each? What does your electrical consist of? Just some questions most people will ask. Hope I helped in at least some way. P Chamfer: This is a chamfer on the end of the pole, it helps to bring the air down around inside of the motor and helps cool the coil better. It also helps relieve the pressure underneath the dustcap. We recommend at the bare minimum to get this option if you choose this series of woofers. Cooling: Self explanatory, the cooling channels are machined into the inside of the sub to help cool the coil FAR better. But there are some things that you sacrifice. There is less metal inside of the motor so it is a little weaker. If you are looking for a tone/burp only scenario for SPL we suggest that you do NOT get this option. Stick with only the P chamfer. Now if you are looking for a daily sub to beat on and you have 2000+ watts the BTL series is for you. Flatwind: The flatwire coil option is standard in the BTL. HiXmCoil: This coil is simply much longer than the normal dual 1ohm or dual 2ohm flatwire coils and allows for more xmax. If you are using this in a daily scenario we suggest that you choose this option, especially in the 15 and 18 inch models. Inner Heat Sink: Its a machined aluminum ring in the gap that lowers the voicecoils inductance (allowing it to play up higher and have a little better overall transient response). It also reduces the volume inside the magnet gap of the motor increasing air speed with the cooling as well as allowing the coil to kick off heat to a more receptive thermal mass rather than magnets. Daily or SPL: Simply put, if you plan on listening to any type of music you MUST choose the daily option. If it is strictly for a competion/tone only scenario then choose the SPL option. The reason we have these options is the gap tolerances between the two are different. The gap in the SPL woofer is much tighter and FAR less forgiving in comparison to the Daily option. The Daily option simply gives the coil more wiggle room inside of the gap to deal with the non-linearity tendencies that you can get into when you are using a sub in a daily driving scenario. Typically SPL applications deal with 1 note and it does not change, therefore we can make the gap much tighter and get all of the motor strength that we can out of it. Universal: This option gives you the choice to later chance the impedence of your voice coils. You can change from dual 2’s to dual 1’s and vice versa by reconing them. If you do not choose this option your motor(s) will be optimized per the coil resistance that you have chosen. (Dual 2’s will forever be a dual 2 motor, Dual 1 will forever be a Dual 1 motor). Enclosures: BTL 12 – Ported box we recommend using 1.75-2.5 cubic feet @ 30-35Hz (I personally think that a 32hz tuning is optimal, and has the most output and is still the most musical daily driving). Use 12-16 square inches of vent area per cubic foot of volume. BTL 15 – Ported box we recommend using 3-5 cubic feet @ 30-35Hz. Again use 12-16 square inches of vent area per cubic foot of volume. BTL 18 – Ported box we recommend using 5-8 cubic feet @ 30-35Hz tuning, you can tune a little higher if you wish but we recommend keeping it close to 32hz for a daily driver. Again the same 12-16 square inches of area applies per cubic foot of volume. thanks for that. I was planning on doing a AQ1200D on each sub, so two subs two amps. For electrical, I plan on having an extra battery running in the back along with a new high output alt. My build: 2001 Toyota Camry two 12" Kicker l7 Solo-Barics Kicker 1500ZX Amp 0-AG Wiring Pioneer DEH-3300UB Head-Unit
