WTT For: Line Driver , 8ga wire
SojiaRaggs9000
Just trying to see if I can get anything decent. My little sister need some bass lol. Im in search of a decent line out convertor... Im aware that I could use the Epic-150... but its for my sister that know nothing about car audio.... I want something simpler but with a gain dial.Can add cash if needed.
Items Of interest:
. A decent Line Driver
. 8ga wire
Audio Control Epic-150 - I made up a cigarette lighter hook up for it. Works great I only used this for testing voltage and how a new rated on the 150db SPL meter it has. (How close is the meter to a Termlab? I don't know, never had it tested) -
Specs:
Bass Restoration processor with SPL Display
SPL Display with Microphone Included
Para-BASS EQ
Patented Pass Restoration Circuit
Battery Voltage Indicator
Speaker Level Inputs
Balanced Differential Inputs
White LED Underglow Kit - BNIB (Brand New In Box) Full underglow kit never been used. It also has a wireless remote feature. Just opened the box today to take pictures -
Griffin iTrip - "The Griffin iTrip is a tiny and compact FM transmitter built for iPods. Once connected, users can tune into FM radio stations anywhere from 88.1 up to 107.9. Plus, the unit sports selectable LX or DX modes of broadcasting, which means superior sound quality with reduced background interference." - Had this for a couple years only used it for a bit before I got my iPod adapter for my Eclipse Headunit. This Griffin iTrip works great. - iPod not Included, was just used to show the Griffin iTrip works.
Kicker KX 350.4 - Four channel amp for trade. Its the older version that was replaced by the ZX series. Looks good and runs great. Missing the 4 screws for the face plates but I can get some new once if needed. - TRADED
Eclipse 8445 8volt head unit - The head unit powers on , knobs work and light up and everything. But the display isn't working so you can't see what your doing. If you can find a faceplate it will be good as new. IIRC eBay has one for like $27. You might also be able to fix by just replacing the ribbon. Ill try looking into that. It has 4 sets of preamp out puts! REAR , FRONT and NON-FADER. It also has AUX output, CD CHANGER plugin as well as a SIRIUS plugin. Eclipse doesn't make this 8volt head unit any longer!! Comes with harness, manual, remote, mounting hardware, 2 trim rings and an extra faceplate and faceplate ribbon. . Last time I looked these sell for $399.99 new and around $250 on ebay IF you can find them. Considering there disconnected you could be hard pressed to find any on ebay. - TRADED
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
i have a sa-8 if u r intrested pm me
2001 gmc seirra
5.3 auto 3.73 locked rear, long tube headers, offroad y pipe, duals, cai, black bear tune, 2/4 drop, 22s, rockford fosgate mods and highs and 4 ab hd 15s and a ab 750.1
1995 civic
1.5 auto slower then hell, dropped on coil overs, ex hub caps, 2 12 trunk, have 450 bucks in the car and gets 35 mpg
1992 s10
being bagged, shaved, and small stereo. right now a pile of parts
PM'd
if anyone want the specs on the amp....... here ya go
•4-Channel KX-Series Power Amplifier
•Low Impedance Operation
•SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
•MOSFET Power Supply
•KickBass: 0-18 dB @ 40 Hz
•Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
•High & Low level inputs
•Custom tooled gold plated connectors
•SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
•Cast aluminum EndKaps
•RMS Power Ratings:
◦14.4V:
■60 watts x 4 chan. @ 4 ohms
■90 watts x 4 chan. @ 2 ohms
■175 watts x 2 chan. @ 4 ohms
◦12.5V:
■35 watts x 4 chan. @ 4 ohms
■70 watts x 4 chan. @ 2 ohms
■130 watts x 2 chan. @ 4 ohms
•Input gain control: Low Level (170mV - 5V), High Level (340mV - 10V)
•Dimensions: 16" L x 10-1/8" W x 2.5" H
03 Santa Fe E A 200 amp alt,JVC AVX840,kenwood 6.5 fr speakers,eclipse 6.5 rears,mids/high amp XTA-2160, sub amp XTA-5000d,0 guage throughout,batts-front/1 batcap 2000,rear/ batcap4000,2 C&D Dynasty agms, subs 2 DC XL M1 15"s in a music box tuned to 28hz....for now.
ttt
ttt
ttt
None, not even a recone?
TTT CAN ADD CASH IF NEEDED.
A trade for the amp is pending.
  • Who's Online   1 Member, 0 Anonymous, 1618 Guests (See full list)
