Lower the resistance the more power the amp puts out. That amp will throw 2200+ rms at 1 ohm. And stock electrical won't cut it for that much power. Would need at least big 3 done with upgraded bat up front and couple big batteries in the back.
:nea:
yeah u hook them up to the alt but make sure u have fuses on each run of 0 gauge u use
to make this clearer, 1/0 wire goes from + on alt to + on front battery, then from front battery + to rear battery +. fuse the run also. then just ground the rear batt to frame
Edited by Kranny
