SPECIFICATIONS:
4/3/2 Channel Bridgeable Class-AB Amplifier
MOSFET PWM Power Supply
Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
Variable Subsonic Filter
Independent 1/2 and 3/4 Channel High Pass Filter Variable
with x 10 Range Selectable Switch
Independent 1/2 and 3/4 Channel Low Pass Filter Variable
HPF/FULL/LPF Selectable Switch
Independent 1/2 and 3/4 Channel Electronic Crossover Slope Selectable
Switch with 12dB and 24dB Octave
Variable Input Level Control
Input Sensitivity : 200mV ~ 6V
Subsonic Filter : 10Hz ~ 500Hz
Signal Input and Line Out RCA Connectors
Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
Tested Voltage & THD: 14.4V & Less than 0.05% THD
Operating Voltage : DC10V~16V Power Input
Wired Remote Controller
MSRP $549 USD
Rated power output
----RMS power, 4 ohm stereo
100W x 4CH
----RMS power, 2 ohm stereo
160W x 4CH
----RMS power, 4 ohm bridged
320W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
THD@RMS Watts <0.1%
Channel Separation 75dB
Fuse Rating 30A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 480(L)mm
Team Ampere Audio
Bump for great price! Wish I had the extra cash.
2016 Ford Explorer
2014 Ford F-350 crew cab
2012 Cadillac CTS-V coupe
2008 Lexus GS430
This topic is now closed to further replies.
