when buying ANL fuses does it matter how many amps they can take as long as its more than your alt can put out or close to it. like if i have a 100A alt is it cool that i get 250A ANL fuses. And if i have one size fuse under the hood going back to a back batt does it need to be the same size as the one in the back or is it ok for them to be different sizes?
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
cheapo Legacy coaxes (just for now)
One thing I learned is that put the proper fusing,if you go bigger(twice the size).than why even fuse than?
It's like not puting a fuse at all
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
You fuse a rated amp draw of your amps. Not alternator amperage. If you have a 200 amp alternator and your max draw is 120a then you fuse and 120.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Google it my friend. Ohms law
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
what kind of voltage would or should i be looking at with stock 100A alt and 2 12V batts. 1 SX S3400, and 1 Stock batt (under the hood) and the big 3? i dont know what my voltage is gonna be, need to figure it out, to use Ohms Law, to find out what size fuses to get... right?
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
  • Who's Online   0 Members, 0 Anonymous, 1603 Guests (See full list)
