Ok guys the other day i took my moms car to the tire shop because it had a nail in it. They informed me that my moms passenger side brake caliber was "locked up" or compressed enough that the pads where rubbing the rotor. So the next day i go to autozone pick up a set of pads, a brake caliber and did a brake job
Well today im driving down the road and what do i notice. The same shit has happened again. I bled the break lines again and toped off the fluid and its still not wanting to release.
So what could i start to look at next? Would the brake booster be the culprit?
FYI car is a 92 olds cutlas ciera
trash stuck inside the caliper. replace both fronts or get rebuild kits
Already replaced the passenger caliber and the driver side is fully functional
IT'S CALIPER!!!!!
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
IT'S CALIPER!!!!!
rofl
doesn't matter, both sides need to be replaced. The newer one will exert more clapping force. so its a safty issue. Lets say you hit the brakes in the rain, one side may lock up or might bite just hard enough to throw balance off and go in a spin
alright man ill replace the drivers side, what would cause the passenger side to stay locked up? it was locked up before, replaced the caliper and its doin the same thing
let me guess, try and push the caliper back and its got an assload of resistance but if you crack the bleeder on the caliper if goes back nice and easy? if thats the case, throw a set of brake hoses on it. I run into this at work all of the time on brake jobs.
And FYI, hoses and calipers should ALWAYS be replaced in pairs unless you like having a possible brake pull.
Kenwood DNX-893s
2 Dat 4.125's
2 Sundown Zv5 12's
Lots of Hushmat
2017 Comp Vehicle
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
newls1
kingsuv
kingsuv
you could have a serious kink in your lines not allowing fluid to flow back, clogged t blocks, could have been left over trash in you lines got in the new ones.
I would disconnect the line and see if you get a decent flow, not pouring, but a quick drip.
does it have ABS?
sounds about right once pressure is built up it wont budge until you open up the bleeder. thanks man ill throw a set of hoses on it tomorrow and replace that other caliper. i didnt know they should be replaced in pairs. learn something new everyday
  • Who's Online   0 Members, 0 Anonymous, 857 Guests (See full list)
