i had a 150 amp fuse on 4gauge to my t1500.1 bdcp. it was doing the same thing yours was doing. it melted the fuse holder and fuse so i removed it and went with just a strait run of 4 gauge wire from the dis block to my amps i put a 250 amp fuse before my dist block everything has worked great for me ever since.
P.S. my manufacture recommendation for my t1500.1 is that i put a 200 amp fuse before the amp problem is that my amp only takes a 4 gauge wire so i figured if i put the fuse before both amps t1500.1 and a t400.5 that 250 amp fuse would work great! hehe it does!
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
make sure every nut and screw on that fuse holder is tighter than a virgin. im not kidding. loose connections at the fuse holder can lead to melted fuses and melted holders, which yours sounds like its already in the process of doing.
