daniel1204 Posted October 10, 2011 Report Posted October 10, 2011 I have 2 of these Amps and they have 2 rcas like most Amps one red and one white, red is labeled low input and the white is labelled low output I want to run both off one set of rcas can I use one end of the rcas white and red and run one to each end of the low inputs? And also it has the Rms rating and it has @full channel driven what does this mean? All the stuff is here in the link if what I asked makes sense http://www.audiolinepro.com/azx800M.html I Am Never Wrong, Just Often Mistaken......
traxxas101 Posted October 11, 2011 Report Posted October 11, 2011 be more specific, i understand how the rcas work but what exactly do u want to do? and i think that the full channel driven RMS means the channel is driven at full power then tested.??? im not rlly sure yet
01VWGREENMACHINE Posted October 11, 2011 Report Posted October 11, 2011 well the low output would be if you had 2 of the same amps and you wanted to supply the second of from the first amp. what i would do if i was you is take the 1 set of rcas coming from the deck and plug 1 rca into each amp problem solved http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
