You have a real nice sq amp for low power, its 35x4 at 4ohm and 45x4 at 2ohm it was one of the best amps that thay made nice sq but dont make alot of power sounds nice with some good comps, you can send it to me and i will take good care of it for you... :yahoo:
lol I need 2 channel amp, so i'm guessing it's 90wrms @ 4ohm? What about gains and other stuff, how do i tune that? btw, payed $8 for it.
Who did you take that from? Great amp. Very clean power and underated.
local flea market. Some guy was also selling Farenheit clx 340-2, but wanted $80 for it.
See the lil black gain pots on the board there should be holes in the heatsink for them that's the gain left and right for each channel
found the gain you were talking about. But, which one is what?
There's 4 right? Each pair is left and right for that channel. Nowadays they use for per channel makes it easier. Turn them both equally
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
they are all turned equally. Do i still need to run active crossover?
