JaeGuerra_57490 Posted October 16, 2011 Report Posted October 16, 2011 i would like to use the spare tire well because i want to fit 2 15's in the back but i was curious because the spare tire airspace would be such an odd shape,would this affect the airflow or how it sounds? im going to attach some pix of the trunk let me know what u guys think?the dimensions one th biggest box i could fit is 36x36x16 and the spare tire well is not an exact size because it varys on the size goes from tall to short but its 34x18x10 so gives me about an extra 2 cubes
STEvil Posted October 17, 2011 Report Posted October 17, 2011 depends on the final design of the box.. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
armykyle1 Posted October 17, 2011 Report Posted October 17, 2011 depends on the final design of the box.. this, if you're building into there make sure you smooth all the edges. I would suggest keeping the ports away from it TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
JaeGuerra_57490 Posted October 17, 2011 Author Report Posted October 17, 2011 depends on the final design of the box.. this, if you're building into there make sure you smooth all the edges. I would suggest keeping the ports away from it what do u guys mean im lost lol should i maybe try and stay away from using the spare tire because i can get 12.28 cubes from just using the whole trunk as a box but thats without subs and port so i have no idea how much it would be taking out
JaeGuerra_57490 Posted October 17, 2011 Author Report Posted October 17, 2011 depends on the final design of the box.. this, if you're building into there make sure you smooth all the edges. I would suggest keeping the ports away from it wait maybe i kinda know what u mean so id say keep the port away from the middle most likely would it be fine on the right side of the box?
STEvil Posted October 18, 2011 Report Posted October 18, 2011 just dont jam the port into the hole, leave some space. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
