does anyone know if you can use an external hard drive to plug in a head unit with a usb interface?
You should be
USB Port: The Kenwood KDC-248U features a front panel USB (1.1/2.0) type-A port that is hidden behind a flip-up cover. The USB port enables connection and control of a portable USB mass-storage class (MSC) device with MP3 (8-320 kbps) and WMA (32-192 kbps) music files. The USB port is compatible with all USB mass storage class devices that support the FAT16 or FAT32 file system. Your USB device should only have a maximum of 8 folder layers, 255 folders, and 255 files per folder - with a maximum of 65,025 files and folders. USB portable audio players that can be charged via USB will be charged when plugged into the CD receiver's USB port, and the vehicle's ignition switch is set to ACC or On.
taken from crutchfield http://www.crutchfield.com/S-s2zrt2SzXhx/p_113KDC248U/Kenwood-KDC-248U.html#details-tab
1999 Jeep Cherokee SportLifted on 31'sPopcorn Sounds AX6000.1 w/ AA 500.1 "THE F1X" board4 Obsidian Audio OA15's
C pillar wall @ 29hz
^^^work in progress^^^
