Posted (edited)
Ok re-did the box, added the 45's in there and calculated their displacement, should be good to go now. If someone could check me and see that im right that would be awesome!
Thanks again y'all!
Edited by someone1
Posted (edited)
almost got it. in torres calc i noticed you didn't have a value in for baffle thickness, enter.75 in there. also, a second baffle and some cross bracing wouldn't hurt.
edit: i guess the calc automatically assumes .75 if there's no value put in there. still would reccommned a second baffle at least
Edited by 412 CVX
More box builds
I'm with captain stupid.
Lol yea thats why i wasnt worried about putting that in, but It'll raise the tunning to 33, so ill have to remake the model and get it back down to 32. And would you think 2 1" dowels would be good? One that goes from the base to the top (ceiling if you will) and one that goes from the front (where the sub is) to the rear? I'll remake it and see what you think!
Ok how about this? lol Or am I lacking something else? (Dont worry about the double baffle for the moment)
well you're a little over on the port area per cube, but not much. i don't think that will hurt anything
More box builds
Me either, at least from what I read, as long as it's over the minimum then I believe it'll be ok, but other than that is it ok?
