gufman Posted October 22, 2011 Report Posted October 22, 2011 Here's whats going on. I have 2 12" Fi BTL N3's. I have an AQ3500d.1 powering them. The manufacturer says the amp is stable @ 1ohm. My question is, can the amp be stable down to .75 or .5 ohms? 2006 Toyota Corolla 2 12" Fi BTL N3's AQ3500d.1 (bass) Kenwood mids, tweets & 6x9's Kenwood 2 & 4 Channel Amps (mids & highs) 160 amp alternator Big 3 Alot of 0 awg power and ground wire www.youtube.com/mastagoof
armykyle1 Posted October 22, 2011 Report Posted October 22, 2011 personally I wouldn't run it @.5 but there's been a few do it... I would feel much safer running .75 with proper electrical TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
gufman Posted October 22, 2011 Author Report Posted October 22, 2011 personally I wouldn't run it @.5 but there's been a few do it... I would feel much safer running .75 with proper electrical Ok, the subs are dual 1's and I have them wired in a series-parallel, this way they are at 1 ohm at the amp. How would I wire them to be at .75 ohms? 2006 Toyota Corolla 2 12" Fi BTL N3's AQ3500d.1 (bass) Kenwood mids, tweets & 6x9's Kenwood 2 & 4 Channel Amps (mids & highs) 160 amp alternator Big 3 Alot of 0 awg power and ground wire www.youtube.com/mastagoof
bumonskateboard6 Posted October 22, 2011 Report Posted October 22, 2011 personally I wouldn't run it @.5 but there's been a few do it... I would feel much safer running .75 with proper electrical Ok, the subs are dual 1's and I have them wired in a series-parallel, this way they are at 1 ohm at the amp. How would I wire them to be at .75 ohms? Not possible. 1ohm is fine for them and the amp. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
