3 Hifonic's Dual 4 OHM down to 1 OHM
Ok so i have 3 Hifonic's Hfi 12's 300 Watt RMS Dual 4 Ohm. Now all 3 in the same box, have 1 set of terminals each on the back of the box, which means they are now wired to 2 OHM's a piece?... am i right?... now if i run another parrallell circuit from those 3 back to the 1 terminal on my amp that makes each speaker wired to 1 OHM now am i right? Kinda new at this stuff so im learning.
you can either do 2.67 or 6 ohm with those subs
http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~3~I~42
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
i was just looking at that diagram when you posted back, and i see now how it would be, so wire one of the neg to one of the positive, the remaining neg and positive on that sub go to the back of the box, repeat on other 2 subs, then run parallel back to amp. got it :D thanks man.
  • Who's Online   0 Members, 0 Anonymous, 1066 Guests (See full list)
