Amp goes into protect when car is running
Hey guys im installing my friends system right and i got everything hooked up and he wanted everything to be oem intergrated so i did and everything works when the car off.. Amp stays on and sounds good! When i start the car the amp start to go into protect and then out almost like its flickerin on and off.. WTF!!! Idk whys its doin this can you guy plz explain i checked the ground but not the positive lead yet so idk also i put a volt meter and its like 13.8 when the amp is off but when i turn it on it drops to about 12.6 then cuts on and off when the cars running.. Member the amp is at idle Plzz get back soon guys i need ur help!
Sounds like ur shorting out sumwhere.
U have a power and ground touching.
Check ur power lead wire and make sure its not cut or nothing
^ this
What did you use for the amps remote turn on?
4 fully loaded Fi sp4 15's
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
Pioneer avh-p4200dvd
All crammed into a mustang.
http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
the ignition wire.. but that doesnt matter bc even if i make a jumper and use the + on the amp for my remote it still goes into protect! <_<
Damn I was thinking it had something to to do with your remote. I can't think of any thing else that would cause your problem. I hope you figure it out good luck
2 Crescendo bc5500s
Crescendo c1100.4
6 focal mids
Vifa tweets
5 XS Power d3100's
  • Who's Online   1 Member, 0 Anonymous, 1679 Guests (See full list)
