What will I need to handel 3k? Would I just be able to just run it off extra batts?
Right now I have all stock, but I have a bigger battery than needed for it from Duralast.
Its a 03 Jeep Grand Cherroke. Thanks! Btw, I plan on running this
http://www.crescendoaudio.com/product.php?productid=17515
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
in my 96 i put a 160 amp alt out of a 98 with the 5.9 and 2 extra red tops in the rear and a adjustable voltage regulator and running a old school autotek mm 4000.1 and i see very lil voltage drop. so try finding a high amp factory alt and sum agm's if its a buget restricted build
Team DBs (Driven By sound)
Alright, thanks for the info guys. Think im just gonna go with a factory one & 2 XS Power batts
Team Subsonic Lows
why would he need a high out put alt?....
i had a audioque 2200 at .5 ohms with 1 stock battery and 2 dekas and never saw below 13.1
i clamped the audioque at 2850 at 1 ohm so im sure it did more at .5 ohm
car was a 07 honda civic
not saying that you all are wrong, im just wondering.. because ive never had a issue now my next set up will need a alt i know forsure but i dont think 3k rms would
Edited by MR. Z
Well the amp does close to 3.3k @ 1 ohm and lilttle over 4k @ .5ohm
Edited by evermaxx
Team Subsonic Lows
true i just looked at the specs sorry man but like someone else has said, if your short on cash... get a stock alt from a new year car with the same motor as you
i wouldnt want a 60 amp alt running my 4k system. your asking for problems that way. you'll kill your alt or a battery or ever worse your amp.
