i made some copper plates that you screw to the battery terminal then the plate has four threaded holes for your ring terminals. makes it look a lot nicer and a ton easier to work on. but they only work if you have a battery without posts. im not using them anymore and i have tons of materials to make more if you want some.
i need these wires to have fuses on them they are all rated differently
thx though
im a bit slow today but it sounds like the frnt batt... best thing i could tell u is to get a 0 gauge fused link and run it to a distribution block ....then to you wires...the 4 gauge (if this is the frnt batt) would be pcm wire,alt wire & the pcm or fuse-box wire...the alt should have a inline fuse already (and you need to run 0 gauge frm batt to alt with a fuse) pcm/fuse box should already be fused & the starter wire does not need to be fused(i have not seen 1 starter fused in the 20 years i have been messing with cars)...gap insurance is a insurance policy you can get through most dealers when you buy a car that will pay of the loan no matter what you do to the car that totals it...ie wreck,ELECTRICAL FIRE,or any thing else that would put you with out a car....lol
ok so i went to ford and this is what i found out:
the dual fuse assembly as ford calls it has: two 4 gauge wires coming out
-one with a fuse of 120a is for the power distribution
-one with a fuse of 200a is for the Generator
these ones don't have a fuse:
-one 4 gauge for the battery junction box
-one 8 gauge for the starter motor
and the two I added:
-one 4 gauge changing to 1/0 gauge asap for amps with fuse
-one 1/0 for alternator with fuse
what i'm looking for is something to hold all the fuses for these wires
make it look presentable. thx for the help so far
p.s. I wish i could get gap insurance but i live in Saskatchewan Canada the provincial government has the rights to the insurance. it kinda blows
Edited by max.krupski
check out toolmaker on caco he can make something for you
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
  • Who's Online   0 Members, 0 Anonymous, 2541 Guests (See full list)
