4th order? I guess.....
bassrace
I want to build a new box.... I'm really thinking about doing a bandpass but idk... I was trying to go for #'s but I would rather have a low end daily driver. My equipment is 2 AQ HDC3 12"s and an Orion 5000D. All I want to go for is a low end beast(slight exageration being I have only 2 12"s). I need yall's opinion on this ppl, this is going in a trunk.
Hopefully I can descibe this ok.. But what I was thinking was my seats fold down soo I would have the port through the hole behind the seats. This is the only pic I had showing the hole.
I was thing subs in a v, firing towards the cabin and port.... Does this make sense??
Give me some opinions... Should I just stick with a regular ported enclosure or will a 4th order most likely fill my needs for the low end.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
What I am thinkin is like a tiny blow through, basically. Would I still get a good output from the subs even though I dont have alot of cone area? or is this a bad idea, as in for what I want(Lowwwws)?
Edit: I am not the most knowledgable person when it comes to bandpasses. From what I unerstand if you want a large bandwith range you loose a good deal of output..?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
  • Who's Online   0 Members, 0 Anonymous, 611 Guests (See full list)
