95' Maxima Box Design for a single SXX15D2
I'm trying to design a box for a single SXX15D2 for my 95 Nissan Maxima. These is what I've come up with so far.
The specs for the woofer are as follows:
15"
   Mounting Depth - 8.4 inch
   Mounting Hole Diameter - 14 inch
   Overall Diameter - 15.5 inch
   Bolt Hole Circle - 14.65 inch
   Motor Width - 7.3 inch
   Motor Depth - 3.6 inch
   Basket Depth - 4.8 inch
   Displacement - 0.18 cu. ft.
   Weight - 27.6 lbs.
Would a box 16" tall be big enough for a 14" mounting hole? the overall diameter of the woofer is 15.5".
The RE Box calculator gives me a totally different tuning frequency than Torres Box Calculator. I realize they're 2 different programs, but which is more accurate?
Any feedback or suggestions would be appreciated :D
1995 Nissan Maxima GLE
JVC KD-APD49 Headunit
(4) Infinity Kappa 652.9i components @ 2 ohm
(1) Infinity Reference 475a amplifier
(2) Skar Audio V-VXV1 12D4's
Hifonics Brutus 2100.1 @ 1 Ohm
add strength as in brace it with mdf triangles?
I would do 4.0^3 with a 4" port (PVC) 4 inches long.....*****Remember to round the inside of the port both front and rear*****
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
If I were to make a square port box, like I'm suggesting?
Slot and Round ports
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) T165.2
(2) T169.3
problem with this. you have a port that is big enough to touch 3 sides of the box (assuming you're doing a standard L port box). if you are, you need to put in "3" for # of common port walls.
edit: and 50hz is a REALLY fucking high tuning dude. why do you want to tune that high?
Edited by Kranny
I don't want to tune that high. The RE Calculator gave me 35hz as a tuning frequency with these same dimensions. That's why I asked which calculator was more accurate.
re calculator sucks compared to torres. read what i said in bold to fix your tuning problem.
  • Who's Online   0 Members, 0 Anonymous, 1650 Guests (See full list)
