Hey how's it going fellas...I have a lil problem that I'm hopping u guys can help me fix....
My amp is making my subs make sort of like a wind blowing sound and sometimes it makes them pop or u can say a loud hard bass note for a few seconds.....
I know its not my subs because I've changed them 3 times already just to make sure its not the subs that r blown...but it keeps making the same noises/sounds.....so hopefully u guys can help me out and figure this out.
Any help/advice would b appreciated
Edited by P-rez
Its All Good!!!
Build on hold...
swing by our shop so i can take a look at it bro, i get the feeling your box is too big but it could be a setting
A wind blowing sound? As in motor noise/ RCA induced noise? Check your ground... Make sure it's tight and not corroded. Where is your amp grounded at? What headunit are you running? Are your Rcas running next to your power wire?
What do u mean my box?.....
And my first box was a prefab with 2 type r's then later changed to type x's
And now I have a Sackett built 15 in a Steve Beatz box.....its 19H.....13.5D.....47W tuned to 32hz
Its All Good!!!
Build on hold...
My amp is grounded on the rear wheel-well....my HU is a pioneer avic z110bt....and yeah my rcas r next to my power wire....is that a problem?
Its All Good!!!
Build on hold...
outter dim you gave is almost 7 cubes for 1 15?????
way to big hope thats for 2 15's
