Electrical Problems...
So my terminals had a crack in them so I replaced them and the car worked for abit... now it wont turn over and I think its the starter are there any tests I can do from home to check if it is indeed the starter? I mean my lights are dim but when I tryed to jump it and other things to charge the battery it would not work and the battery is new... I know its hard to tell over the net but if there is a test I can do that would make it easier!
It wont turn over.. Elaborate. Does it just make a 'clicking' sound when you turn the key? Or does it actaully crank but not start? Or do you get nothing at all? Turn your high-beams on and have a buddy try to start it. If the headlights dim right out, you have a bad connection somewhere..
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
Check fuses also. I blew a fuse on my gfs car and it wouldn't start but the lights worked.
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
The car makes no noise other then a scratching noise from the engine bay on the passengers side I think its the starter but I cant afford to buy the starter and that not be the problem because im broke... by lugs do you mean terminal? When I try to turn the lights on they dont come on and I know thats the battery but ... this was a problem before the battery died since its very new?
the two clamps that go on the battery itself so the car can get power. theres one for + and one for -. can you wiggle them around? because they're supposed to be snug as fawk.
measure the battery voltage with a multimeter. 12.6v is resting voltage, which it should be right around there. 12.0 is too low.
Those are battery terminals they are tight :D but they were loose when I opened it up that may be the problem hmmmm ill try charging the battery or changing it... but that wouldnt account for the starter noise...
