Clear Sound Build - Focal, Audiocontrol, Rockford Fosgate, and FI
So I got it all done, here are the pics:
Foam tape around the inserts to allow for vinyl and suede gap:
Insert made with body filler:
This area was a pain in the butt to get right...
Same here:
Vinyl Wrapped:
Everything else wrapped:
I think it came out real nice. Now I just have to wait for my wire to get here and start that part of the build...
-Mark
Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel
Check out my forum section here on SMD for my builds and tutorial videos!
Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication
Looks clean. great job!
2004 Dodge Ram 1500 Single Cab
26" rims on 305/30/r26
Panasonic In-Dash
15" DC Audio XL
Hifonics Brutus 2000
Memphis Bass Enhancer
MUCH MORE TO COME
Oh btw I must add the rage gold is amazing. I had bought the extreme before as I expected it would be better than the gold. While it might be better for a painting application I have to say for something like this where pin holes are not a factor I was able to sand and get my curves in record time.
Everything you see here took me about 3 hours in filling and sanding time. No power tools. Of course I made sure I was attentive and sanded in the green stage in order to knock down the high areas easily but regardless this stuff works amazingly.
I am definitely more confident about taking on more curvy jobs that require wrapping now that I know how quickly I can accomplish it effectively.
-Mark
Ok so after a lot of debating between the BL and the Q I decided to get an 12" FI BL. I took advantage of their black Friday deal for all the free options. Can't wait to get the beast. This leads to my next question:
I am going to do sub forward. This decision will make sense once you see my plans for the entire layout. The question is should I do port forward as well or port up? Keep in mind I have a nice big 6" by 10" hole in the rear deck where the factory amplifier used to reside. If porting up I would shoot directly through this hole. What do you guys think?
-Mark
Here is my plan for the box. I will build it this way so I can try sub forward and sub backward. If I like one more than the other I will just switch the bottom of the box around so that the contour for the amp rack is on the side I want it. I can then proceed with doing my fiberglass fork to add the professionalism to the install.
Note the kerf's :)
-Mark
