Posted (edited)
need help and inputs in building a box for my FI SSD 15 with options. to be powered by sound magus x1502, i usually listen to house and hiphop music,but now i want to achieve more lows... i used to have a JBLp1222 on a sideport box,now im going to use a 15" so i dont have that much idea on how to work on the box (box dimensions,port etc) i hope someone could help me.im going to put it in a minivan (mitsubishi adventure) thanks Guys. :)
Edited by carloidol
The site recommends tuning of 33-35 hz at 3-4cuft optimal...is it safe to tune higher? like 37-38 hz? i want to have lows but sometimes i want to play house music so i want my bass not that delayed...is this fine FI users? what box volume would you recommend? should i follow the optimal size?thanks for your help...
Posted (edited)
This doesn't make sense.. You want to tune higher for SQ purposes? And what do you mean 'delayed'?
Edited by loudNlow87
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
i want to tune higher so i can still keep up with tight, punch bass but at the same time to have Lows,but my main goal is to have deep low bass...if i am not mistaken if you tune your box low it will cater more on lows but sometimes may be a little delayed on fast tight bass?am i correct? thats why im asking so i can have idea on what box am i going to build...
yeah you are right, im thinking of going on 35 hz. hehe...more or less sir 412 cvx what would you recommend on the cu. ft of the box? is there a drastic change in rearfire or upfiring the sub? thanks...
