Audiobahn A18001DT --350.00 Shipped
Class D Circuitry;Double Sided Glass Epoxy Circuit Board;Remote Bass Control With Blue Backlight Knobs;Variable 18dB Low-pass Crossover : 50Hz to 250Hz;Variable Bass Boost : 0 – 18dB;Variable Bass Boost Frequency : 40Hz – 100Hz;Subsonic Filter : 20Hz to 50Hz;Large Display Volt Meter With blue Illumination;Throughput RCA Connections;4-way Protection Circuitry : Thermal, Short Circuit, Overload, and DC Offset;Dual Cooling Fans;High Gloss Chrome Plated Finish.
Polk Audio PA500.4 --200.00 Shipped
125 watts x 4 continuous, 200 x 4 dynamic power (2 ohm load), 4 channel mode.
250 watts x 2 (4 ohm) continuous power, 2 channel mode.
CEA-2006 Compliant specifications for true, accurate power ratings.
4-channel, dual bridge-mono (2-channel), or dual simultaneous stereo/mono operation provide a variety of configurations and setups: 4-channel for front and rear speakers; 2 speakers and a sub; 2 subwoofers; or 2 subs and 4-channels in passive-tri mode.
2 ohm stable 4-channel operation.
High-speed MOSFET switching power supply and high current Bipolar Output Transistors pump maximum voltage and high current to your speakers or subwoofers.
Double Layer Fiberglass Epoxy Printed Circuit Boards for more rigidity, less shrinkage and a smaller overall amp footprint.
6-Way Smart System Protection (SSP) circuits
Cadence 4 channel--100.00 Shipped
Q 4000
Power
4 X 60 @ 4 Ohm
4 X 100 @ 2 Ohm
2 X 200 or 1 X 400 @ 4 Ohm Mono
Freq Resp 20Hz-30Khz
SN Ratio >100dB
THD <0.05%
Damping>200@100Hz
Channel Sep>65dB
Dimensions (LxWxH) 12" x 10.75" x 2.4"
Class AB 4 Channel Stereo Amplifier
2 sets of Polk Audio db5251 5 1/4 components --115.00 shipped Each
Dynamic Balance® Polymer/Mica Composite Cones are stiff yet lightweight for big sound, small distortion.
A 1-inch Liquid-Cooled Silk/Polymer composite Dome Tweeter with Neodymium magnet gives db Series component systems clear, detailed highs.
and 6 stinger 0gauge to 4 gauge Adapters 10.00 each shipped
Please help out, My alternator just fried on me and it's 450 for a new Mechman. In a world of hurt here so please shoot me an offer.
polk components are NEW, polk amp is NEW (never seen power only mounted to amp rack to see the look)
adapters new in package, cadence and audiobahn amp work fantastically, Audiobahn is pre-ebay whore out. Oh and shipping in the 48 only.
Edited by larrys95civic
Adding my subs and another polk 500.4, Or if your interested in my wire or what ever shoot me a pm. I need an alternator bad and i'm having a little money trouble (wife and I are separated so I'm giving her my check to support the house and kids. Anyways up next is 4 Rockford Fosgate P3's Dual 4 ohm. They are ran off of 2 polk audio 1200.1's strapped and tuned with a DD-1. before alt died amps set steady during heavy bass at 13.3.
Other polk 500.4 is 180 shipped.
subs are 110 each shipped.
or if interested in anything in my sig pls pm me.
