Hi everyone,
i'm masterkiwi from holland, i'm driving a 323f mazda build '98.
there is a world of options i could choose in subs and amps, but i'm totally lost.
I have an eye for these two:
1x P3D412 with a p1000 in 1ohm mono, specs here: rockford datasheet (page 5)
2x mivoc aw3000 with (no amp desided yet) specs here: Mivoc datasheet
by the way, everything is expensive in holland (2.32 dollar per litre benzine) so i have a LPG-system, with the gastank in the trunk. i have about half my trunk left for some subs.
what do ya'll think is a good idea, or even has an even better idea?
Rockford site doesen´t open, i found no pirce for the Mivoc. I did a research at E-bay for the RF prices and it looks that you want to spend like 500 € for both.
I guess you this My link sub in D 4and as amp something what putting arround 500 watts at 4 Ohm (like this9. Have a look at German E-bay we biggest carhifisection in Europe.
If you have question´s shoot me a mail. Other good idea for amps are the Hifonics BRZ line.
"in the abundance of water, the fool is thirsty" Bob Marley
well, the mivoc is about 50 euro's and the rockford is about 300 euro's.
Here the specs (sorry the mivoc is in german, it's a german brand):
mivoc:
Aussendurchmesser 312 mm
Einbaudurchmesser 284 mm
Gesamthöhe 138 mm
Einbautiefe 124 mm
Nom Impedanz / Re 4 / 3 VAS 97 l
Belastbarkeit R.M.S. 180 W
max. 450 W
fs 27 Hz SD 507 cm²
Qms 4.1 Mms 129 g
Qes 0.33 Schwingspulendurchm. 63 mm
Qts 0.31 Schwingspulenhöhe 18.8 mm
Schwingspulenindukt. 1.4 mH
Bxl 14.1 Tm Xmax +/- 6.4 mm
SPL 93 dB
Einsatzbereich 25 - 800 Hz
Rockford p3:
Size 12"
Nominal Impedance Dual 4-Ohm
Power Handling 600 Watts RMS
1200 Watts Max
Voice Coil Diameter 2.5"
(65.5 mm)
Magnet Weight 96 oz.
2.73 kg.
Speaker Connector Dual 10 AWG compression
Fs (Hz) 27.7
Re (Ohms) 6.40
Le (mH) 6.94
Qms 5.60
Qes 0.57
Qts 0.52
Vas (Liters) 57.7
Sd (cm2) 570
SPL (dB @ 1w/1m) 85
Xmax (mm) 15.9
Woofer Displacement 0.194 cu. ft.
(5.5 Liters)
Cutout Diameter 11.25 in.
(285 mm)
Mounting Depth 6.66 in.
(169.3 mm)
As i see it, the mivoc is way better, it goes lower in hrtz and spl is way higher.. and the best thing, it uses less then half the watts to get more..
Nothing happen, if you look in my avatar you will see that im from Germany, easy to read.
I think the Mivoc is more a bassdriver, not a sub speaker. more to use for kickbass and producing less lowbass.
Did you know if the Mivoc is out of a caraudioline from Mivoc or is it from there home hifiline. Its more a speaker
like My link the speakers in the door in this link.
You get no real subwoofer in a pricerange of 50 € in Europe, maby a used one from a friendley friend.
I guess you again the German E-bay, last year i shoot a used Focal My link, who was like new for 30 € + shipping.
  • Who's Online   1 Member, 0 Anonymous, 1657 Guests (See full list)
