Hi my name is raphael im from Brazil ( Pernambuco ).
I have been looking around inside the forums here if some one could help me with a sound system i have here, i cant spend alot of money because audio equipment for cars here in brazil are very very expencive so ill do with wat i already have here:
3x Bravox Woofer 200w RMS 8 ohms (each)
im thinking in buying the new soundigital SD250.2D here costs aproximatly R$185,00 ( in dollars its $104.69 )
could any one telme is i could charge those three woofers with one or two SD250's os i would need 3 amps, one for each woofer?
Or i can use only 2 woofers with one or two amps.
I couldn't find any forum here in brazil that could help me out, thx.
  • 1 month later...
probaly need at least 1 amp per woofer wired way down to give you that 250 watts get a bigger amp, a mono block
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
If you get 3 of those 8ohm woofers and wire them all together in parallel it should put your total impedance down to a little over 2 ohms. Not a good idea for such a small amp. Have you considered running only 2 of those subs? Wiring two of those 8 ohm subs will get you a 4 ohm load and the full 250 watts out of that Sound Digital amp.
My Current Project: 2006 Ford Focus ST
HU: Kenwood KDC-X986
Amps: Rockford Fosgate R300-4
Hifonics Brutus BXi 1601D
Sub(s): (2) Skar VVX8 want to add 2x
Mids/Highs: VXI65 components (front doors), RE Pro 5x7FR (rear doors)
Wiring: Big 3 done in Candace 1/0 awg.
1 run from battery to distro-block 1/0 awg. Cadance wire
4 awg Stinger wire from distro-block to amps.
Electrical: stock alt.
Optima Red Top.
  • Who's Online   0 Members, 0 Anonymous, 917 Guests (See full list)
