marknotts Posted November 15, 2007 Report Posted November 15, 2007 Hi there, I want to build a vented box for 2 Splinter sound RL-i8's which needs to be around 0.6 cubes for both. The only problem is, my port calculation program is telling me that due to the high xmax, for 35hz tuning I need a minimum diameter of 6.53 inches and 117inches long!!! Not practical! If I use 4" OD tube I'm getting around 37" which is still too long for the small box really. Should I use an even smaller port tube? but wont this cause turbulence and noise? or make the box bigger (not sure what effect this will have on power handling and SQ etc) or just tune higher? Will a flared port help in reducing turbulence and noise, such as an aeroport?
07mazda3s Posted November 15, 2007 Report Posted November 15, 2007 I'd do a slot port Power Acoustik fubar 12 sony xploding amp 2 ft^3 box @ 35hz
marknotts Posted November 15, 2007 Author Report Posted November 15, 2007 I'd do a slot port I could but that will be too long too, unless I wrap it round and round the box which would be a construction nightmare!
07mazda3s Posted November 15, 2007 Report Posted November 15, 2007 Try changing the dimensions of the port. Power Acoustik fubar 12 sony xploding amp 2 ft^3 box @ 35hz
Guest MegaloManiac Posted November 15, 2007 Report Posted November 15, 2007 You are using 8" subs. to tune low(in small box) the port would have to be long. I contemplated on using an rli8 as well. I discovered to get a decent tuning youd have(not necessarly but more than likely) to use external ports if used aeoroports. the port would have to be 43.15" long for a tuning of 25hz but it be actually 44.15" long with the flares. (btw these numbers are for a single 4" precision Port)
marknotts Posted November 15, 2007 Author Report Posted November 15, 2007 Try changing the dimensions of the port. I think whatever the dimensions are, a certain area still needs a certain length. The only way I can come up with a smaller lenght is to use a smaller cross sectional area which I think will cause turbulence and noise? Or use a larger box or tune higher???????
