98Chevy Posted November 23, 2011 Report Posted November 23, 2011 I have a 400 watt power acoustic amp 2ohm stable it will come on but once hooked to speakers goes into protect.. Anybody able to give me a reason why and is it fixable If It's Not Skar It Shouldnt be in your Car! SKAR AUDIO FTW!
bass_stalker Posted November 23, 2011 Report Posted November 23, 2011 what ohm load are you hooking it up to, have you checked for loose connections or any thing like that JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
98Chevy Posted November 23, 2011 Author Report Posted November 23, 2011 Nothing loose and I was just testing it by hooking it too a q power deluxe and it kept doing that If It's Not Skar It Shouldnt be in your Car! SKAR AUDIO FTW!
Guest Posted November 23, 2011 Report Posted November 23, 2011 you aren't answering his question. What ohm load is the woofer? also, is the woofer blown? That can cause the amp to go into protect
98Chevy Posted November 23, 2011 Author Report Posted November 23, 2011 No woofer was good and I beleive they were 4 ohm If It's Not Skar It Shouldnt be in your Car! SKAR AUDIO FTW!
bass_stalker Posted November 23, 2011 Report Posted November 23, 2011 is it the Gothic series amp? i had one that i did in an ice chest radio that i couldn't get to come on no matter what, the only way i ended up fixing it was by taking it out and hooking it up in another car, i think it reset the amp or something, maybe check your RCA's too because i remember the one i had wouldn't turn on unless it had good RCA's plugged in JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
