AlpineGuy87 Posted November 16, 2007 Report Posted November 16, 2007 Well, i took out my other bulb, hooked up everything accordingly, flipped the lights on and they HIDs dont turn on...? 06 SCION tC
Low n Loud Posted November 16, 2007 Report Posted November 16, 2007 you probably checked to see already if you hooked it up backwards (+ into -), or if there the kind of HIDs where the ballast needs to be grounded separatly, maybe the ground is bad. Or, do you have daytime running lights?
AlpineGuy87 Posted November 16, 2007 Author Report Posted November 16, 2007 No daytime running lights. And the ground goes right into the connection for the stock connection... and pretty sure that the + and - are in right spots... cuz the clip is on only one side and it says (-) and (+) on the sides 06 SCION tC
Low n Loud Posted November 16, 2007 Report Posted November 16, 2007 seems kinds primative, but shake the ballast to make sure u dont hear anything rattling around lol, could be broke or faulty. and i really doubt you touched the filiment on the HID itself, cuz that would be bad
AlpineGuy87 Posted November 16, 2007 Author Report Posted November 16, 2007 I've tried the other ballast on the same connection, nothing tried the other HID bulb and nothing... 06 SCION tC
AlpineGuy87 Posted November 16, 2007 Author Report Posted November 16, 2007 it came with couple screws, and says "Waterproof washer included" so is that all in regards to "cutting" the neg (-) and mounting it? two screws for the ballast and 1 extra... is that the ground maybe? and the instructions didnt really say to cut it.. 06 SCION tC
Low n Loud Posted November 16, 2007 Report Posted November 16, 2007 sounds to me like they are broke. get in touch with where you got them and see if u can xchange them or get yourmoney back. btw, who makes them?
AlpineGuy87 Posted November 16, 2007 Author Report Posted November 16, 2007 sounds to me like they are broke. get in touch with where you got them and see if u can xchange them or get yourmoney back. btw, who makes them? Xenon they are brand new, no scratches, nothing.. 06 SCION tC
Low n Loud Posted November 16, 2007 Report Posted November 16, 2007 it came with couple screws, and says "Waterproof washer included" so is that all in regards to "cutting" the neg (-) and mounting it? two screws for the ballast and 1 extra... is that the ground maybe? and the instructions didnt really say to cut it.. no dont cut it. by all means, if this is a simple plug and play HID kit, all you should have to do it plug.....and whala
AlpineGuy87 Posted November 16, 2007 Author Report Posted November 16, 2007 no dont cut it. by all means, if this is a simple plug and play HID kit, all you should have to do it plug.....and whala exactly!! I plugged everything in! no other way for any of these other connections to plug into anything else, its all straight forward 06 SCION tC
