Jd1102 Posted November 26, 2011 Report Posted November 26, 2011 if you do the remote wire check also don't have your remote wire hooked up could melt it i have seen it happen before Quote
TheNewbie Posted November 26, 2011 Author Report Posted November 26, 2011 Any other ideas? Just rechecked ground. It's good. u can check your remote by using a jumper from power to remote just don't leave it like that just check it Alright, well progress. The light turned on when i did that, so that means my remote isn't hooked up properly? Quote Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
Jd1102 Posted November 26, 2011 Report Posted November 26, 2011 Any other ideas? Just rechecked ground. It's good. u can check your remote by using a jumper from power to remote just don't leave it like that just check it Alright, well progress. The light turned on when i did that, so that means my remote isn't hooked up properly? yep not hooked up or just bad Quote
TheNewbie Posted November 26, 2011 Author Report Posted November 26, 2011 The deck remote wire or the wire it'sself. It's as simple as hooking up the blue wire on the back of the deck to a wire that goes to the antenna wire on the amp right? Unless i've forgot something. It's quiet frusterating. Quote Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
Jd1102 Posted November 26, 2011 Report Posted November 26, 2011 The deck remote wire or the wire it'sself. It's as simple as hooking up the blue wire on the back of the deck to a wire that goes to the antenna wire on the amp right? Unless i've forgot something. It's quiet frusterating. remote from cd played to remote on amp no antenna at all but it could be the back of the cd player not working or it could be the wire pinched or grounded on the way to the back Quote
TheNewbie Posted November 26, 2011 Author Report Posted November 26, 2011 Not sure what you mean grounded on the way to the back. Quote Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
TheNewbie Posted November 26, 2011 Author Report Posted November 26, 2011 Sooo found the problem you weree right it's the back of the deck unfortunately. SO i'll go pick up another connecting thingy. Quote Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
