i want to see if i can do a ported box for 4 10's behind the third seat
dimensions
width: 48inches
height: anywhere from 12-16
top depth: touching seat to back door about 12 inches
bottom depth touching seat and door about 14-15 inches
power for the tens will be provided by a powerbass xa 3000d @ 1 ohm
im willing to pay for a design.
as far as tuning goes i want it from 28hz to 35hz
any help is appreciated
That's only 4 cubes gross. Lookin' at about 2.5 cubes after subs/port/bracing. Kinda tight.
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
That would work a bit better.
Sub Amp: AB 450.1
XS D3100
Come on 150!
I can design a box, I'm not going to charge. But if you feel you do need to pay, hit up someone like RAM-Designs. :) What do you mean by port "touching" the seats?
Sub Amp: AB 450.1
XS D3100
Come on 150!
Where do you plan on mounting the subs if 12"D is touching your back door?
Sub Amp: AB 450.1
XS D3100
Come on 150!
Honestly, if I had that amp with that little space you have, I'd go with two nice 10's. Give yourself plenty of port area and volume at the same. Throw in a couple Fi Q 10's or something along those lines that can really use that amp.
Sub Amp: AB 450.1
XS D3100
Come on 150!
  • Who's Online   1 Member, 0 Anonymous, 2506 Guests (See full list)
