I just picked up a Alpine MRD-M1000 mono block for $100 today and need help setting it up. I downloaded the manual offline but its not very help full. Its pushing 2 Earthquake DBX10 in a ported box. Each dbx is in a 1.75cu.ft tuned at 33 hertz. Also my deck pre-out are 2 volts.
Here what I got so far from what I was able to find online
1-1 Input : 2ch
1-2 Input Level : 0db (what is this used for)
1-3 Gain Factor : 6db
2-1 LP On\Off :On
2-2 Frequency :80hz
3-1 Subsonic On/Off :On
3-2 Frequency :25hz
4-1 Parametric EQ On\Off
4-2 Frequency :
4-3 Width Q. :
4-4 Level :
5-1 Bass Compensation On\Off
5-2 Mode :N\A
6-1 Time Compensation On\Off
6-2 Delay Time :N\A
7-1 Phase :0\180
8-1 Amp Set ID No. :1
8-2 Time Of Delay :1.0
9-1 Output Disable :Off
0-1 Memory Write :Hopefully Correct Settings!!
0-2 Memory Read :Hopefully Correct Settings!!
Any help would be great, thanks
Edited by JRminivan
So what do you need help with .. ?
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
setting the gains, sorry, I downloaded the manual but it doesn't explain much and the settings and what they do. Like the input gain goes from 0db to -24db but not sure on what its used for. Parametric EQ, Bass Compensation should I use them?
ok so what I was able to find online is Parametric EQ is bass boost I could leave this off and just use my deck for bass boost. Right?
Input level is for your pre out from your deck, I have 2 volts rca out so what should this be at? I have it at default 0db.
Please correct me if I'm wrong.
Edited by JRminivan
  • 1 month later...
when i had that amp i had the LP filter at around 80. subsonic was 1/4 the way (32hz) gain i had 5/8 but gain should be set properly .
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
