how to wire down two 3ohm woofers
not sure if its the same as the w7s are they the single 3ohm coils?
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
Doesnt each of those subs only have one coil? I would wire the coils in parallel. That way, the impedance will be 1.5 ohms.
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
yes, 1 coil. i ment the topic to say 2x woofers.
so from the amp positive and negative to the woofer, then from the first woofer pos and neg to the 2nd woofer?
Yep, that would work fine
2008 Toyota Corolla
-Skar VVX 12 D4 (2)-Skar SK1500.1-Pioneer DEH-80prs
your amp should have 2 outputs 2 pos and 2 neg but in theory pos to pos neg to neg. depending on the size wire you are using can be hard to fit into push terminals. so it will be wired to 1.5
well yea, im using the aq1200. so which outputs would i use from the amp?
You can either use one or both from the amp depends on your terminal situation going into the box which ever will be easier
  • Who's Online   1 Member, 0 Anonymous, 1054 Guests (See full list)
