Jeremy1998 Posted December 5, 2011 Report Posted December 5, 2011 Ok, I used the calculator, and it says this is right, but I am never too sure about my ability to type the right numbers in the right places... So... Here is what I came up with. Can anyone check it for me? Sub: Fi Q 18 (these measurements are internal dimensions. I will calculate the outside dimensions when I actually make it.) 60" high 24" wide 18" deep 40" port lenth 24" wide port 6" tall port tuning: ~28hz And I drew this in paint in case I don't make sense.
loudNlow87 Posted December 5, 2011 Report Posted December 5, 2011 It's pretty close. Your port AND box can't be the same width, though. You gotta subtract material thickness. which will change tuning/port area a bit. What kinda net volume were you seeking? '11 Jeep Patriot New Build Head Unit: Pioneer AVH-P3200DVD Front: Massive CK69 Components Front Amp: Massive NX2 Rears: Infinity Kappa's Subs: 8 Sundown SA-8 v2's Sub Amp: AB 450.1 XS D3100 Come on 150!
loudNlow87 Posted December 5, 2011 Report Posted December 5, 2011 7.9 cubes @ 28Hz 123" port. '11 Jeep Patriot New Build Head Unit: Pioneer AVH-P3200DVD Front: Massive CK69 Components Front Amp: Massive NX2 Rears: Infinity Kappa's Subs: 8 Sundown SA-8 v2's Sub Amp: AB 450.1 XS D3100 Come on 150!
Jeremy1998 Posted December 6, 2011 Author Report Posted December 6, 2011 It's pretty close. Your port AND box can't be the same width, though. You gotta subtract material thickness. which will change tuning/port area a bit. What kinda net volume were you seeking? No, the port is 24 inches wide. Using 3/4 mdf, the outside would be 25.5 inches. The measurements are the internal dimensions... I will calculate the external dimensions when I make it.
