1988JimmyRE Posted December 18, 2011 Report Share Posted December 18, 2011 Battery from XS Power, Big 3, that should do it. Quote BUILD LOG-->1988 S15 Jimmy V8 4x4 2 15" RE Audio<--BUILD LOG Link to comment Share on other sites More sharing options...
2007TBSS Posted December 18, 2011 Author Report Share Posted December 18, 2011 (edited) Big 3 will be plenty for you... Even with the new amps? 1/0 to the back? Chassis under the seat or frame ground in the back? Edited December 18, 2011 by 2007TBSS Quote JVC AVX840 Xtant 604x Xtant 403a 2 RE SEX12's Polk Audio DB6501 Front and back http://www.stevemeadedesigns.com/board/topic/127503-re-12s-box-build-system-complete/page__p__1794327__fromsearch__1#entry1794327 Link to comment Share on other sites More sharing options...
LoudBimmer Posted December 18, 2011 Report Share Posted December 18, 2011 on the budget, I would drop something like kinetik hc1800 or xs power D1200 would be enough Quote Link to comment Share on other sites More sharing options...
Boilermaker-744 Posted December 18, 2011 Report Share Posted December 18, 2011 Big 3 will be plenty for you... Even with the new amps? 1/0 to the back? Chassis under the seat or frame ground in the back? Even with the new amps, yes! Any of the 5 bolts in the rear cargo area will work also... 1/0 run from the front to back should be fine as well... Quote Link to comment Share on other sites More sharing options...
2007TBSS Posted December 18, 2011 Author Report Share Posted December 18, 2011 Big 3 will be plenty for you... Even with the new amps? 1/0 to the back? Chassis under the seat or frame ground in the back? Even with the new amps, yes! Any of the 5 bolts in the rear cargo area will work also... 1/0 run from the front to back should be fine as well... The cargo bolts? Awesome! Quote JVC AVX840 Xtant 604x Xtant 403a 2 RE SEX12's Polk Audio DB6501 Front and back http://www.stevemeadedesigns.com/board/topic/127503-re-12s-box-build-system-complete/page__p__1794327__fromsearch__1#entry1794327 Link to comment Share on other sites More sharing options...
2007TBSS Posted December 18, 2011 Author Report Share Posted December 18, 2011 on the budget, I would drop something like kinetik hc1800 or xs power D1200 would be enough Off to search. Quote JVC AVX840 Xtant 604x Xtant 403a 2 RE SEX12's Polk Audio DB6501 Front and back http://www.stevemeadedesigns.com/board/topic/127503-re-12s-box-build-system-complete/page__p__1794327__fromsearch__1#entry1794327 Link to comment Share on other sites More sharing options...
