XS Power
I was needing helping picking out a battery for my grand prix. The max Dimensions: 10" L x 6-7/8" W x 7-13/16" H is what I can use Im sure I can go a little taller and that would be it. I need it to also be my starting battery. I am running right now about 1500 watts rms on a stock alt I plan on upgrading to a mechman soon. The max I will push through the battery is 2700 watts that would be after a mechman alt. Any help is greatly appreciated.
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
TaylorFade, on 02 Jul 2013 - 9:38 PM, said:
Go back to that place, ask to speak to that dude again, look him dead in the eye and then.... pop him in the snot box.
Tell him T-Fade sent you.
i think that car takes a 75 series battery right? call xs they can tell u what will fit
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
To be honest with you im not sure
Group 78 so Im going to call first thing in the morning.
You can probably fit a D3400 under the hood. Most are able to with little to no modification at all. If you are going to be running 2700watts through it, then you will probably want to add a smaller battery to the back to help give you some capacity to pull from.
