Ian01 Posted December 25, 2011 Report Posted December 25, 2011 I've been roaming through www.compusa.com lately to get some DDR3 ram to upgrade my computer when I came across a hard drive type that are common in some laptops and gaming computers called solid state drives. In the past the idea has been tossed around with some success of using a conventional external hard drive (I have one but I'm not willing to reformat it anytime soon). The initial problem is, when you hit a bumpy road, not only will it skip.. but even worse you MAY damage the disk all together. Is there a possibility this will be a solution to this because it's a set of chips opposed to a disk? and should SSD formated correctly work in a car? ·· YouTube ·· ·· The Ride · The Audio ·· ··· The Toy ···
splmark Posted December 25, 2011 Report Posted December 25, 2011 I have a 500gig in my car with movies, pics and music. U just have to format it the right way. I had to use fat32 but if u do that u can only use 32 gigs. I did a search online and found a format that is fat32 but tricks the radio into using all 500. Ill have to search tomorrow and find out what its called http://www.termpro.com/dbdrag/memberalbum/34416a0.jpg
Ian01 Posted December 25, 2011 Author Report Posted December 25, 2011 I have a 500gig in my car with movies, pics and music. U just have to format it the right way. I had to use fat32 but if u do that u can only use 32 gigs. I did a search online and found a format that is fat32 but tricks the radio into using all 500. Ill have to search tomorrow and find out what its called That's cool, a 500gb SSD?? would be so much stuff in the car lol... ·· YouTube ·· ·· The Ride · The Audio ·· ··· The Toy ···
96Blazer Posted December 25, 2011 Report Posted December 25, 2011 I was thinking of putting a hard drive in my vehicle but was unsure of how the hard drive would react to bumps and shock. A solid state drive would totally eliminate all of that worry, good thinking! 2001 GMC Jimmy SLE 4X4 Floor Shift AutoHeadunit - Alpine CDA-117Front Door Speakers - Alpine SPS-600C MidsRear Door Speakers - NoneDash Speakers - Alpine SPS-600C TweetersSub Amp - Rockford Fosgate T4002Mids+Highs Amp - Rockford Fosgate P4004Subwoofer - P3D215 Fosgate Punch 15Sub Box - Rockford Fosgate designed "powerful" ported box Built by myself i would rather run cheaper but sexier then expensive and fucking ugly.
