carshateme Posted December 31, 2011 Report Posted December 31, 2011 I have been building all my boxes by just pure volume and I learned you want to build the box by power you're running your subs...what does this mean necessarily. And can someone explain how OHMS affect your subs...like if I got 2 subs dual 4 ohms, would it better than dual 2 ohms. Since dual 4 ohms parallel wired is 1 ohm and dual 2 ohms is parallel wired at .5 ohms Compared on a 1 ohm stable amplifier? New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
ChrisLun Posted December 31, 2011 Report Posted December 31, 2011 More power the smaller the enclosure...depending on woofer manufacturer....larger the enclosure for less power....call it talk to your woofer manufactuer to learn about desired specs 2006 Dodge Charger (2) Kinetic 3800 (1) DC Power 270XP (4) T1-12D4 (1) T2500BDCP (2) T400.4 7.5 cubic ft. (2) 6 in ports thru the rear deck (2) T165.2 (2) T169.3
carshateme Posted December 31, 2011 Author Report Posted December 31, 2011 More power the smaller the enclosure...depending on woofer manufacturer....larger the enclosure for less power....call it talk to your woofer manufactuer to learn about desired specs This make sense now. Thanks. Just to make sure. If you're running max rms on your subs...your enclosure would want to be smaller. New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
ChrisLun Posted December 31, 2011 Report Posted December 31, 2011 Yes and no...depends on the subs 2006 Dodge Charger (2) Kinetic 3800 (1) DC Power 270XP (4) T1-12D4 (1) T2500BDCP (2) T400.4 7.5 cubic ft. (2) 6 in ports thru the rear deck (2) T165.2 (2) T169.3
