Jason_D Posted January 2, 2012 Report Posted January 2, 2012 what is there out there that will do this? i got 2 sets of components, so a 2 channel that can do 300 RMS per channel, or a 4 channel with 4x150 RMS. Must pe pretty good SQ too. Thanks
AA98hoe Posted January 2, 2012 Report Posted January 2, 2012 I run zapco 750.2s on 14v... they have been tested on the bench up to 18v ...and sound great TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
