ali888 Posted January 3, 2012 Author Report Posted January 3, 2012 lmao how the hell do you have a mono 2 channel? mono means 1 and your choices are .5 ohms or 2 ohms being you dont even know what a mono amp is wire it to 2 ohms one + to the other side of the subs - then the other + to the amp and the other - on the other side of the sub gos to the amp as well lols like opti 6kd it has 1 channel ouput 1+ve and 1-ve if amp like ddz1a has 2+ve and 2-ve wht u call them 1 channel?? its still a 1 channel amp. It just has more speaker terminals to put more wire in. For like running 2 subs you can run all 4 terminals and not have to bunch up your wire into 2. yep make sense Quote @My OpiniOnZ MAy HaVe ChanGeD, But Not The Fact ThAt I'm Right.........!!
ALPINE408 Posted January 3, 2012 Report Posted January 3, 2012 (edited) and again for your awnser you can wire your dual 1 ohm sub to .5 ohms or 2 ohms i can tell you dont know what your doing so 2 ohms it is for safty of your equipment and yourself so you dont burn down your car 2 ohms one + to the other side of the subs - then the other + to the amp and the other - on the other side of the sub gos to the amp as well Edited January 3, 2012 by Team Bassick (ALPINE) Quote Have you ever had your woofers blown?
ali888 Posted January 3, 2012 Author Report Posted January 3, 2012 and again for your awnser you can wire your dual 1 ohm sub to .5 ohms or 2 ohms i can tell you dont know what your doing so 2 ohms it is for safty of your equipment and yourself so you dont burn down your car 2 ohms one + to the other side of the subs - then the other + to the amp and the other - on the other side of the sub gos to the amp as well thnx man infact got wiring pic as well Quote @My OpiniOnZ MAy HaVe ChanGeD, But Not The Fact ThAt I'm Right.........!!
ALPINE408 Posted January 3, 2012 Report Posted January 3, 2012 http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12 you want the 2 ohm pic Quote Have you ever had your woofers blown?
ali888 Posted January 4, 2012 Author Report Posted January 4, 2012 http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12 you want the 2 ohm pic yes 2 ohm for now to be on safe side Quote @My OpiniOnZ MAy HaVe ChanGeD, But Not The Fact ThAt I'm Right.........!!
ALPINE408 Posted January 4, 2012 Report Posted January 4, 2012 http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12 you want the 2 ohm pic yes 2 ohm for now to be on safe side for now and for ever i would not wire to .5 ohms ever if i was you! unless you like blowing shit up and having to buy new stuff Quote Have you ever had your woofers blown?
